  #28 (permalink)
Old 08-06-2003, 07:11 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
"Can you not compensate for a weak squirter / accelerator pump by richening up the idle with the mixture screws? I know this is only a bandaid, but it seems to help the transistion from idle to enrichment circuit."
You shouldn't. what you need to do is play with your accelerator pump cam. Get the kit that gives you a bunch of cams and squirters, try the green cam. Adjust it so it moves the accel pump arm immediately. If the car coughs immediately, bigger squirter nozzle, if it goes than coughs, smaller squirter nozzle (to lengthen pump shot duration) You amy need to adjust the spring loaded accel pump arm "pusher" so it doesn't bind up at full travel.
