Old 08-07-2003, 06:39 AM
bwcobra bwcobra is offline
Cobra Make, Engine: hunter 408 sbf
Default the ones you used are they
the ones you used are they square with a hole on top and bottom to bolt on the motor and then a bolt comming out of the rubber side. I have these but I need more of a kind that a small block would use it's a 2 piece or 3 piece set up. where the part bolts to the motor and the other part bolts to the frame and then a thru bolt goes thru both and then a nut on the other side. how did you use the ones you have what does the frame side bracket look like. thanks for the input.
