Thread: Raydyot Mirrors
Old 08-07-2003, 07:48 AM
decooney's Avatar
decooney decooney is offline
Default where to mount?
Rick,
I've found the windshield mounts work well too. I've done some playing around with three different type custom-made bracket setups. The trick is integrating the mount with windwings (if you have those), mounting them high enough to see over the rear fenders, and also making some brackets that provide additional angle inward so you can actually use both driver and passenger side mirrors. If you mount them to the side of your winshield flat, and forward of the wind wings, the RayDots do not rotate inward enough without some assistance in bracketry/fixtures that will also change the angle inward just a bit more. Good Luck.
Duane
