Old 08-09-2003, 09:26 PM
ERA 626's Avatar
ERA 626 ERA 626 is offline
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
decooney,
see my gallery there are new pictures of the motor.
edelbrock heads, harland sharp roller rockers, flow work done to the heads and intake, comp cam spec.
Part Number 33-246-4
Engine 1963-present Ford
352ci-428ci
8cyl.
Grind Number FB 294S-10
Description
Intake Exhaust
Valve Adjustment 0.022 0.022
Gross Valve Lift 0.605 0.605
Duration At 0.015 Tappet Lift 294 294
Valve Timing At 0.015
Open Close
Intake 41 73
Exhaust 81 33
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 248 248
Lobe Lift 0.35 0.35
Lobe Separation 110
Recommended Valve Springs 924
