Thread: No oil pressure
Old 08-10-2003, 05:09 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
If it helps, the oil should enter the filter through the ring of holes in the outer edge, and come out (and hence go back into the engine) through the central hole.
Check to see if your piping is correct - maybe all you have to do is swap the pipes over on the remote filter head.
The reason you may have no pressure is that if your piping is reversed, the anti drain-back valve in the filter blocks the flow of oil. Many an engine builder has fallen foul of this, so don't even think you are the first!
HTH
Wilf
