Old 08-11-2003, 08:44 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Default Speedo Cable Rotation?
OK, here's a couple stupid question. Which direction does my speedometer cable rotate? Trans is a TKO II.
The reason I ask is because I want to spin the cable with electric drill and make sure my reverse rotation speedo is functioning correctly before I drive the car. Also, if I pull the speedo cable out of the trans, will I lose my tranny fluid through the hole where the cable plugs into the trans (I would guess that I'd lose some, but not all)?
Thanks in advance.
Mike
Replica is not a dirty word.
