Old 08-11-2003, 01:14 PM
petek's Avatar
petek petek is offline
Cobra Make, Engine: CRL, 351W, Tremec TKO
I'm running Holley Projection FI and figured the gauges (in the engine compartment) were cheap enough that I could put one on the feed line and one on the return line. The only time that I've used the gauges so far is when I set the line pressure.
I'd guess that a dash mounted gauge might tell you if your fuel pickup was dry while you went (quickly) around corners.
Pete K.
Who is John Galt?
