Old 08-12-2003, 09:48 AM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Hi,
You are getting oil in the cylinder from the rings not seated yet or the pvc system. Try putting a restrictor in the pvc line and see if it clears, if not then take the cobra out and try tp seat the rings.- do 6 or 8 accereration runs from 2,000 to 4,000 rpm in 3rd gear and let the engine decellerate. This should put pressure on the rings in both directions and seat them. Then drive normally for a few hundred miles and change oil.
Perry.
