Old 08-13-2003, 05:33 AM
Hal Copple Hal Copple is offline
Cobra Make, Engine: Superformance, 396 CI
when i was changing my SPF over to an all AN 12 (from AN 10) system, i had to cut and make lots of hoses, some several times. Used several different oil filter mounts, so over several months, i drained a lot of oil lines.
i was amazed at how little oil is actually in the lines and oil cooler!
My guess is that an extensive AN hose/cooler system holds less than 3/4 quart in the whole thing. Trying to blow it out with air, then starting an engine with dry lines is more risky than i would want to take, to get out about 8% of my old oil.
By the way, i use a Griot's sucker system, just stick the plastic hard tube down into the dipstick hole, pump it about 10 times, go get a beer, and come back in a few minutes, (i slightly jack up the rear of the car to put the front of the sump down just a bit), and voila, in about 10 minutes, my engine is sucked dry. Never have to crawl underneath, and risk some misthreading or leakage at the drain plug.
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
