The casting # is along the pan rail above the starter location. The # you posted is for both a regular engine as well as the CJ (all '72-'74). If the pan isn't off it may only be 2 bolt mains, the Cleveland blocks were all cast with 4 bolt ability but the main caps were different (as well as the finish machine work) on the 4 bolt block. The CJ name was dropped from the engine after '71 and was just referred to as the 4V, they came originally with a cast iron intake that used a spreadbore carb.
WDZ
