Old 08-17-2003, 02:50 PM
ronzara's Avatar
ronzara ronzara is offline
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Default Coolant from Side pipe????
Well,
351W Rebuilt completed,.... Time for break-in......
After about 15 minutes of running (Temp holding at 165).....
The motor began blowing anti-freeze out the Drivers side Side-Pipe.......Along with white smoke.....
I checked the 5,6,7,8 Plugs...... # 5 was very wet.
So,... pulled intake back off..... (thought it could be intake gasket).... while I was there, I removed the Header and checked head torque.... (thought; head gasket) all was fine.
Looking into the chamber of #5, it was flooded with green coolant. I dried it out and and replaced all the intake gaskets (cafefully) and reassembled everything.
Drained all the old oil and replaced with fresh.
I started the car,...... SAME THING??????
Any ideas or suggestions???
BTY,...... before 1st start up, I had wired the distributor to 302 Firing order....... DUhhhhhhhh
And had a couple back fires, (obviously),... then I figured out what I did..... Could this have caused the problem??
thanks.
RZ
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
