Old 08-18-2003, 11:18 AM
ronzara's Avatar
ronzara ronzara is offline
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Roscoe,
I used sealant on head bolts you're refering to. I am using a weiand stealth Intake, and Ford GT-40X Heads,.... None of the bolts run through the water jackets. Both the heads & intake use 6 bolts on either side, instead of the 8 like normal 351W set-up.
I have AGAIN removed the intake.... Looks like I am getting a wave (almost a crease) in the gasket on the Drivers side Front....... at the front water passage/#5 intake hole.......
Don't know why this is happening. I am torquing the intake bolts to 17lbs. and using the RED sealant around the water passages (behind & on face of gaskets). The 2nd time I also used copper spray the help adhear the gasket to the head to prevent slippage..... I can't figure it out.. the Passangers side has been fine BOTH times !!!! *?*?*
Also I am not using the regular 351W gaskets.... they are not tall enough for the intake ports on the heads.
Any body Know for certain what gaskets I should be using?? .....this must be the problem.
RZ
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
