Thread: Power Steering
Old 08-19-2003, 06:18 AM
Nesato I have the same ps pump on my car. the output is 300 to 375 psi if the pressure valve sticks it will go to 600 psi. I looked at your picture. the hose should not have broken unless vibration caused it. You have the correct couplers for SS hose on the system and assemblied them as pre the instructions. If the line ripped out of the fitting get a new one leave a little play in the line. I use the clamps with the rubber inserts to prevent breaking through vibration. If the hose broke at the fitting I would say poor assembly. I blew a cooler line off my car when doing the break in. Didnot have the hose far enought on the fitting when tighening the coupler. Reved up the motor to 3 grand and pop off came the line 85 psi blew it off. Hope this helps Rick Lake
