Old 08-19-2003, 06:35 PM
DanElam's Avatar
DanElam DanElam is offline
Send a message via ICQ to DanElam Send a message via AIM to DanElam
Default Video
Get a little video from the track, will you? We are going to run the Spec Racer National Championships at Las Vegas later this year and I'd like to see the track.
The Skippie book talks about late apexing if you are pushing to the edge. It wasn't meant as a comment on the handling. It means you have turned too early if the wheels are straight.
If the turn is 120 degrees, there is a good chance that it is a double apex turn. Which turn is giving you the problem? It might just be that you've got more HP than traction and there isn't going to be much that you can do.
Good luck. Sounds like you're on it!
