Old 08-19-2003, 09:18 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Question
Johnnycobra;
I assume the engine is installed in the cobra with a manual tranny. Most likely place to look is the clutch disc. Did you install it correctly?....... the center of it should have the 1/2" center section sticking out towards the tranny, if you put it facing the engine then it will touch the flywheel bolts.
Good Luck,
Perry.
