Old 08-20-2003, 07:25 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
When you put a car on a lift, the hydraulics lift the car, then you slowly lower it to the mechanical stops before going under it. Don't rely on hydraulic pressure with a jack or a lift to keep several tons of steel in the air above your head.
