Old 08-20-2003, 01:01 PM
blykins blykins is offline
Reason being, I had a problem with my main girdle and the holes not being drilled true. I had to bore them out.
Johnny, I really wouldn't worry about it at all. If all your bearing clearances were fine, let it go.
What did the piston manufacturer recommend as a piston-to-bore clearance? I guess it differs from each piston manufacturer, but I think mine was .004". Like I said before, you're dealing with high compression...it's not gonna turn like it does with just the crank in the block. You're turning a lot of mass...with a lot of compression.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
