Old 08-21-2003, 08:24 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default Glad to hear you survived, "Indy" !
Best wishes for a speedy recovery. This incident will set back your "guinea pig" status (EFI test subject) for the rest of us that are about to install a Holley system. It is interesting to note that the 36 lb injectors do work after all, on this size/powered motor.
The troubles with various basic/donor IRS systems are why I went with the 9 inch straight axle rear system (and the West coast) it seems bulletproof. If I do change to a custom IRS later, it will be CWI.. I have inspected a CWI 9 inch center IRS install, firsthand at a local rod and custom shop...it at least LOOKS impressive!
Try taking lots of MSM (joint rebuilding sulpher) as an aid in healing..You can get it at Costco Ginseng will help too.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
