Old 08-21-2003, 08:54 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
A cast dist gear is fine, unless you have a roller cam, then you need a steel or bronze dist gear. With a tappet cam, they have cast cam gear, so run a cast dist gear as well.
the polymer gears I don't think are recomended for engines that still use the factory oil pump, I think you need a dry sump or there will be too much load on the gear (I think, may be wrong)
