Thread: Dieseling 427
Old 08-22-2003, 07:55 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
to Cracker,
the original rear suspension on my Contemporary Cobra was a Jaguar-Salisbury setup with inboard brakes.
There was no way of keeping those brake disks free from oil mist from the differential, even after replacing several times the output shaft seals. Got bloody hands every time when taking the rear inboard calipers off and on, so I decided to replace the rear end with an AMP setup , which takes the brakes outboard. The lower aluminum control arm is an extra to this modification and works fine in my car .I also got the Watts linkage upper support, which bis great for cornering.
If you wish pictures of how the setup looks like, let me know.
Check out AMP web page at:
(www.cobracountry.com/amp/home.html)
