Old 08-22-2003, 10:43 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
Default WINTER!!!!!!!!!!!
Lets not jump the gun here
Install the MSD and rev limiter, new hood and trunk props, redo the seat padding, change the gas peddle geometry, size and location, install horns, install brake vent covers, take windshield apart and install new rubber and tensioner, correct upper seat belt mounts, bead radiator pipes and perhaps switch over to all rigid pipe, finish off heater/defroster installation, new weather stripping, make and install door sills, rearrange gas filler for better filling and track down gas odor issue, make new caliper adaptors and mount 12.19 rotors on the front (perhaps even adapt the existing front 10.75s to the rear end), make and install spats, line wheel wells with some sort of material to cut down on noise and damage from rocks being thrown, install invinsa sheild on the bottom of the fenders behind the rear wheels (hoosier td pick up everything!), disable lever shocks and install the double adjustable tube shocks in the front.
The list is a LOT longer, but if I get this done this winter, I will be a pretty happy camper.
Next winter..... rear brakes if not done this winter, complete R&R of front suspension including a new fully adjustable coilover setup, adjustable rollbar and suspension tuning.
Rick
OhioCobraClub.com
LondonCobraShow.com
