Old 08-25-2003, 12:12 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I think your motor is not balanced correctly. Does the shake come back at 4400 rpm? You did get the pistons balanced to one another, then the rods, then have the: crank, dampner, flexplate balanced to the bobweight of the piston/rod assembly, right?
