Old 08-26-2003, 01:30 PM
Jamo's Avatar
Jamo Jamo is offline
Super Moderator
What it can take these days...
Shelby Aluminum Block $5150
CP Forged Alum. Pistons 855
Clay Smith Mech Roller Cam 308
Comp Cams Mech Roller Lifters 320
Edelbrock Alum Heads (2) 1010
Shelby Timing Cover 125
Manley Valves/Assembly 700
Shelby Intake 420
Velasco 4.250 Crank 1950
Holley 850 DP 482
MSD Billet Dist 260
MSD Plug wires 100
MSD 6A Box 194
Starter 310
McLeod Clutch/Flywheel 983
Alternator 170
T&D Roller Rockers 940
Pushrods 120
Valve Covers 200
Aviad Pan 615
Dampner 285
Manley Rods/Clevite Brgs/Mains 890
Speed Pro Plus Chr Moly Rings 103
Melling Hi Volume Pump/Shaft 90
$16580 These items only.
Does not include gaskets, fastners, etc. Total bill for parts was $17,931.88. Obviously, I got a bit of deal on some of the stuff (Velasco crank, heads), while other items are off the shelf costs.
Labor [Build/ Major Head Work (4400), balance (135), test run (450), etc.] $5075 Obviously, build costs will vary significantly depending on what is done to the block (Shelbys do need some work) and the heads for increased flow.
I paid 22,526.38 plus the scattershield, remote oil filter adaptor, rear puke tank fitting for manifold, water pump, pulleys, etc.
Throw in some freeking tax, and that's how you spend $25K real damn easy.
Hope this answers some questions. You don't have to spend what I spent--many alternatives for parts, and some of the labor (heads) depends on what you want. I still think you need to figure on around $20K for a Shelby-based motor.
Jamo
