Old 08-26-2003, 03:55 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Do you want a different tranny so you can have overdrive? The C-6 is ford's strongest automatic. You can have the upshift/downshift RPM adjusted to better suit your desires. You can also manually upshift an automatic with a ratchet shifter, that's what the drag racers do. What exactly are you dissatisfied with?
