Old 08-27-2003, 10:24 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
It's true that U-joints need to be run at a minimum angle just to keep the needles working in their cups. Otherwise the needles will Brinell its cups by sitting in one location and beating a groove into its races. As for what static degree this should be, maybe 1-1/2 degrees at each joint, but in opposite directions so the angular velocity changes of the front joint is cancelled out by the second joint.
If you've got a Cobra with a live axle, the driveshaft is short and angles change a lot for each inch of wheel travel. But whatever the angle change, front and rear angle changes should be nearly the same for the reason given above to prevent non-constant velocities at the output end of the driveshaft.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
