Old 08-28-2003, 05:07 AM
ronzara's Avatar
ronzara ronzara is offline
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Bob,
No, I can't feel any unusual vibration in the motor. It does not jump around or wobble on the motor mounts.
I will check out the drive shaft, but I doubt if this is the problem due to the fact that I ran the car for about 4 months prior to this engine teardown and rebuild. there was not a problem when the car was parked. Also it happens when the car is in Park as well as Drive.
Mr. Fixit
The block never left the Car. The motor was disassembled and reassembled while still in the engine bay.
Flex plate was not touched, nor was the Crank shaft.
Everything was changed except the Block, Crank, Flexplate, Balancer & Carb.
I changed Pistons & Rings, Connecting Rods & Bearings, Heads & all valve train components, intake, cam, lifters, pushrods, waterpump,
Yes the shifter starts viberating at 2200 rpm, both in Park and While in drive. >>>Stopped and/or while moving<<<<<<
I don't notice it coming back at 4400 though. It might, slightly, but not as severe as the lower Rpm.
Guys, I really appreciate your input on this. I am scratching my head here....
RZ
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
