Old 08-28-2003, 05:37 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Urgent MSD Help!
Hey guys, here I go again.
Over the last three weeks I have replaced my MSD Box twice, new vibration proof MSD Coil, New Starter switch, New kill switch, new additional ground connections w/ 00 gauge battery ground cable. Again last night I went out to start my Cobra an my starter spins like crazy but it will not fire. So (again) I got out my circuit tester and yep, I am not getting any fire to my coil.
What am I missing? I am tired or replacing parts that probably are not bad. Again here is what I have:
MSD FE Distributor w/ MSD 8.5 mm plug wires
MSD 6AL Ignition mounted above my passenger foot box
MSD Black Vibration Proof Blaster Coil
Battery Kill Switch , Elec Fan Switch, Elec fuel pump switch, and my high and low beam switch also mounted on my dash) all connections are secure and do not shorting out with anything else
MSD Shift light (wired to the ign switch that is getting fire because it lights up when I turn on the key)
I am also using the white wire from my 6AL box for my kill switch
The only two things I have not replaced yet is my distributor and my solenoid.
Could a faulty distributor interrupt the current to my coil? What else can I check?
Quick response would be greatly appreciated. Leaving for Road America next Wednesday.
Thanks for any suggestions,
Clois
"Let's roll"
"Be part of Something Good
