Old 08-28-2003, 10:15 AM
NeedAntiVenom NeedAntiVenom is offline
Cobra Make, Engine: ERA 289 FIA #2086, 302/320 HP, Dart heads, hydraulic
Clois,
Two boxes bad in a row is kind of unlikely - but possible. Hopefully the box is not in the engine compartment. Usually its the simple things. Here are a couple easy things to try...
1) Look for a bad crimp on a connector, or a malformed female connector. Look at both the trigger feed and coil feeds.
2) Set your meter on AC volts and look at the violet/green trigger pair at the connector where it goes into the box - you should get a reading when you crank the engine.
Best of Luck,
Jim
