Thread: Butler Bruised
Old 08-29-2003, 05:54 AM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
Sorry to see and hear about the damage! We spend so long on these things, it's like a knife wound to the gut whenever they get damaged!
Maybe instead of the neutral switch, you should look at a battery cutoff switch? Then you can pull the handle off and put it in a toolbox - it's a little more absolute. They're fairly cheap too and will prevent a drain in the event of a short.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
