Old 08-30-2003, 01:07 PM
aumoore's Avatar
aumoore aumoore is offline
Cobra Make, Engine: Hunter 427, 5.0 (302)
The 3550 should be more tranny than your motor can throw at it. IMHO the TKO is not needed unless you are doing one of the following: using a strong Big Block, running a power adder like turbos, Supercharger or N2O, planning on a lot of drag strip duty using slicks. The TKO costs more and needs a special clutch setup. I have heard the TKO is a little harder to shift than a 3550.
I upgraded to a 3550 from a SD T-5 that did not like my mild 5.0. I called Forte's and they said for under 450 HP the 3550 is plenty.
If you go with either transmission get the McLeod bellhousing, the proper GM syncromesh and a pro 5.0 shifter. Both Tremec transmissions come with a shifter that most people say is junk.
