Thread: fuel pressure
Old 08-31-2003, 04:28 AM
boxhead's Avatar
boxhead boxhead is offline
If your pressure gauge was showing to high a pressure and I think from memory you have an electric fuel pump then I would say it is more likely a regulator at fault, not the carbies.
If your pump has a built in regulator then it may be your trouble, some external regulators are adjustable so maybe this is your problem, the carbies do nothing in as far as controlling fuel pressure
Cruising in 5th
