  #37 (permalink)
Old 08-31-2003, 10:21 PM
Keithc8 Keithc8 is offline
Default 427 Shelby Alm Engine Pricing
I have never posted much on here but we are getting a lot of request for cobra engines. Because of our buying power we can sell most any part at the same price or below as Summit and Jegs. We are doing all alm engines of the dyno with carburator to canton oil pan with msd dist. and wires, Edelbrock water pump, Ford Racing valve covers and all new parts for 17,500.00. These engines will produce about 600HP and 550ft.lbs. tourqe on pump gas. We can build to suite any of your needs and build you a single 4 barrel FE that will make 850HP if you would like. I don,t believe there is anyone out there that can deliver the horsepower for the bucks that we can. We will also build any other style Fe engine you want. Just finished a 427 plus .030, 10.2 to 1, Ford steel C7AE heads with a police interceptor intake and a hydralic roller that made 530 ft.lbs and 540HP and idled at 700RPM's. Just a matter of the right parts and the right machine work with the proper assembly. We dyno test and tune all engines to make sure they are good before they leave the shop. Good luck with your project. Also we will provide Shelby alm. blocks machined for 5250.00 ready to assemble. Thanks Keith Craft
Keith C
