Old 09-01-2003, 05:58 AM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default SBF Timing Question
351W with an MSD Ignition System; what is the correct, preferred, or best way to cold time the ignition.
Being an old points guy, used to set #1 at TDC and make sure that the points were open, then where the rotor lined up that became the terminal for the #1 plug and just followed around the firing order.
In an MSD Dist. being there are no points, how do you make sure that the dist is set to fire?
Tony
