Old 09-01-2003, 08:18 PM
JOHNNYCOBRA's Avatar
JOHNNYCOBRA JOHNNYCOBRA is offline
Cobra Make, Engine: 1984 S-V WITH A 5Liter Eight stack EFI
Default Tooo tight!
I checked the crank end play, It's ok'
all the ring end gaps look right on'
but the pistons drag in the bores quite a bit
with the rings installed. pushing them inside the bore
they drag a lot. but the piston clearance is fine?
I'm still putting the pistons on one at a time to check the drag
and if it gets better or not'
JG
