Old 09-01-2003, 09:29 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Hi,
The #1 plug wire is usually on the front pass side of the dist cap as it is usually the shortest wire,but as long as the firing order is right it can go anywhere.
The out of phase I refered to;
The cam turns 2 times or 720 degrees of crank revolution for one complete firing sequence. So you need to check that # 1 cylinder is at TDC on the firing stroke,compression then both valves cosed.
# 1 will then fire ,go down on power stroke, then piston up on exhaust stroke to TDC again[exhaust valve closing and intake opening-this is the cams overlap, both valves open slightly ] If you line up dist and rotor now it will be 180 crank degrees out of phase and engine will backfire into intake and carb.
Now the piston goes down on intake stroke [intake valve open,exhaust closed.] and up on compression stroke[intake valve closed] to TDC and should fire now, both valves closed. This is where the rotor should point to # 1 plug.
The MSD fires multiple sparks for 20 crank degrees, so the timing looks slightly retarded,I think MSD says you can add 4 degrees more advance to the static timing. I run 16 degrees initial advance.
Perry.
