Old 09-02-2003, 10:24 AM
leslie.files leslie.files is offline
Cobra Make, Engine: Excaliber body, Modified Custom frame
I seem to be having a problem posting today, but here goes anyway. I have a question aboutr the heads. Do you have screw in studs or the pressed in type? sometimes the lift on the cam will slightly pull the studs from the bosses. When I was racing I ran across weak screw in studs that stretched considerable and then broke off at the boss. Don't know if this helps, hope it does!
Tohmer
"Ask not what your country can do for you, but what you can do for your country" JFK
