  #26 (permalink)
Old 09-03-2003, 08:52 AM
JOHNNYCOBRA's Avatar
JOHNNYCOBRA JOHNNYCOBRA is offline
Cobra Make, Engine: 1984 S-V WITH A 5Liter Eight stack EFI
Default Tooooo tight !
Well I finished checking all the rings and gaps, everything looks good
The crank end play is about .008 and good
I re-lubed all the bearings and retorqued everything so I'll be putting the heads back on and setting up the valve lash and the timing.
The engine appears to turn at about the same by hand
I was told you can set up a half horse electric motor to do the break-in, running it off the crank with a pulley.
Is this a good idea?
JG
