Old 09-03-2003, 07:15 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Ron,
Whenever you replace rod/crank/piston assemblies with non-OEM, exact replacement parts, or you're rebuilding a grocery getter motor for more strenuous use; always have it balanced. Best if you balance with flywheel and crank damper so it all spins correctly when you button it back up.
