Old 09-07-2003, 08:45 PM
Paul Sutphen Paul Sutphen is offline
This is in reply to Paul's question about the FE Max Stainless rockers same as Shelby uses. I have been running a pair for at least two years. I had to measure for a new set of pushrods because the stock rods did not work for me. The rockers have performed flawlessly. You may have to change shim washers to position the rocker depending on your heads. I found this to be the case using the edelbrock heads. Also you will want to use studs instead of bolts. These can be purchased through edelbrock dealers.
Paul
