Old 09-08-2003, 08:24 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default My Pirelli P-Zero tires are recommended cold 50 psi
I am running the rears at 40, front at 36
OK, it's a rough ride (with the Carerra coil overs set hard too).. but they handle wonderfully unless you hit a bad bump.. then the tire skates
Low profile tires ride rougher, and the wider they are the more "road things" you hit, but on a good surface they handle WAY better.
Here's a good question for any tire pros out there: If the tire is balanced at say 45 psi, then if you change that to 25 psi, won't it be a tiny bit imbalanced?
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
