Old 09-09-2003, 04:10 AM
Janusz Janusz is offline
Cobra Make, Engine: Shell Valley, 351 Sportsman
The 427 would come into play if you were measuring from the pan to the floor, but the 2" frame to floor measurement is dependant on the suspension geometry . The older SV’s used different length shocks in the front versus the back, whereas the new chassis uses the same shock and a different spring rate. Is there a chance the shocks were switched, which would place the lower spring rate in the front?
Can you estimate the front shock length, mount-to-mount, as the vehicle is sitting with the weight on it? Also how much is the spring compressed with the spring nut (how many inches of thread are showing below the nut)?
