Old 09-09-2003, 01:08 PM
hdheritage97 hdheritage97 is offline
Send a message via AIM to hdheritage97
Default Kevin
I used a Mellings HV pump and the pickup that came with the Milodon pan. I bought a nut and stud setup from Ford Motorsports....the studs thread into the block, you put your gasket, windage tray, gasket, and pan up there over the studs, and then the nuts. I love the look of it and it was much easier than trying to get a bolt through all that and then start it. I'm no pan expert but also not a serious racer either and for the money I thought my setup was very adequate for my usage....street play and cruising.
Cliff
" Like my Grandfather always told me, if you are truly good at something there's no need to brag, others will be sure to do that for you "
