P.S. Once you get the Ohm reading, divide that into twelve. This will give you amps. Multiply amps times 12 and you will get Watts. Make sure the watt rating on the resistor exceeds this number.
eg Ohm reading is 72.
12/72 = .16666
.16666 * 12 = 1.999 (2)
In this case you would want at a minimum of a 2 watt rated resistor. But to be on the safe side I would double the 2 watts to 4.
Watt ratings on resistors relates to how well they can disapate heat.
 "Nobody gets to see the Wizard. Not Nobody. Not Nohow.
