Thread: Hard Starting?
Old 09-09-2003, 07:32 PM
dlowe01's Avatar
dlowe01 dlowe01 is offline
Cobra Make, Engine: RU Carcrafters / 408 Stroker
On mine it just has a real hard time turning over. I have not tried a heat shield on the starter yet. Maybe that will work. Will double check all the wires from the alternator and starter again also. I noticed tonight while on a drive that at idle the voltage meter was only showing about 12 volts. When I reved it just a little it went to about 13. It used to sit at around 14 at idle. Any ideas on that? It's probably all being caused by the same thing, what ever that is?
