Old 09-10-2003, 07:48 PM
hdheritage97 hdheritage97 is offline
Send a message via AIM to hdheritage97
Default Rick
Wow...I didn't realize I was getting in so deep....lol. I'm using Tilton masters with the Tilton balance bar setup. I have a master for the fronts and one for the backs. The rear brakes are GM calipers and the fronts are Jag E-type, not sure if they are Girling but I'll take a tire off this weekend to find out. I'm running BF Goodrich tires all around 235/60/15's up front and 275/50/15 Drag Radials out back. My masters are 3/4" units by the way. As far as what type of pads I have, I don't have a clue since I've never messed with the brakes yet. I've looked at some Jag sites and there is a Wilwood based kit I can buy that adapts to the Jag stuff. They use the Wilwood Billet units, Wilwood pads of course, but mention nothing of the rotors so I assume they use them on the stock rotor, which I would rather change. I'll print your reply and see if I can't find out all the info you were asking about sometime this weekend. Thanks again for taking the time to help me and I'll post that info ASAP.
Thanks,
Cliff
" Like my Grandfather always told me, if you are truly good at something there's no need to brag, others will be sure to do that for you "
