Old 09-11-2003, 03:17 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Change the tranny, instead of the gears. Keep the 3.00 rear gears, and change to a richmond 5 speed, or a g-force 5 speed with gears similar to the richmond. You'll have a true close ratio 5 speed, and not a wide ratio 4 speed with overdrive that you have now. The TKO is a good tranny, I just don't think the gear ratio's are optimal for a cobra, a light car with a high hp engine. The gear ratio speads are too wide.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
