Old 09-11-2003, 08:25 PM
rmb_cobra rmb_cobra is offline
Default NAF Cobra Wiring short
I have an NAF built in 91 that is resurrecting Lucas, oh god of darkness, in my Ford wiring. I did not build the kit, so bear with me: I was working on the tilt column (a portion of it is cracked and I am waiting on it's replacement), and is from a 77-82 Mustang) and the signal apparently shorted out or malfunctioned. Now, no taillights, but the brake lights work, turn signal just turns on, no blinking (same with the hazard lights). No high beams, no dash lights. Runs fine. Headlights work. Any suggestions? I checked all the electrical fittings on the column, relubed with the dielectric grease to insure contact. Only found two fuses, a 20 amp and a 5 amp buried inside the dash. No fusebox visible amid the spaghetti pile of wires. Any suggestions?
rmb_cobra
FST S HL
