Old 09-15-2003, 05:01 PM
Edley Rondinone Edley Rondinone is offline
Cobra Make, Engine: NAF replica, 351W, about 420 HP
"Factory-built" (or Manufacturer-built") means it was built by people that are/were paid to build that particular "car." Usually, on an assembly line, the same person puts the same bolts in the same holes every time. Some factories are less assembly-line, in that a group of guys get together and assemble a car, from start to finish, with time "break-ups" to facilitate time-consuming factors, ie painting, wiring, dyno testing, et al. Hopefully, most manufacturers have some sort of QC on that line. A LOT of variables involved here. In some, if not most instances, a "factory-built" car IS built to a higher standard of quality. AND, in some cases, a "home-built" (NOT home-made!) car is built to a higher standard of quality, due to the unlimited amount of labor that the home-builder is able to donate to the cause. All in all, factory-built usually means professionally-built.
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
