Old 09-15-2003, 05:57 PM
Rick Orsini's Avatar
Rick Orsini Rick Orsini is offline
Neil,
Thanks for the response. I'm running the SDS computer setup with custom wiring. The computer is running open loop with no O2 sensors. The intake is a custom stack EFI and the rest of the motor is pretty stock 1991 5.0. The only other performance mod is roller rockers. I just downgraded the injectors from 24lb back to 19lb as is was running really hot. I had been running the standard EEC IV setup with a Cobra intake before the upgrade and that ran fine.
Today I went back through it and reset the base timing on the engine and the computer and re-entered all of the default values for the computer. I was able to get it started and running, though it still runs rough. I took it around the block a couple of times, but am still apprehensive about taking it any distance. Once I'm sure it'll stay running and get me home each time, I'm going to take it to a dyno to tune it. I've got a lean/rich meter that is hooked up and I've been using that to tune air/fuel at different RPM levels.
I'm sure once I get it on the dyno, I'll be able to get this thing dialed in. Thanks for the additional info.
- Rick
