Old 09-16-2003, 02:20 PM
decooney's Avatar
decooney decooney is offline
Hey All, here is a quick update on the final window sticker sample.
just got back from the print shop. They provided five different type samples. Front, Front/Rear dual-image, White backing, Clear backing, sticking from inside, sticking from outside... too many decisions !@#$%^&*()_.
After covering their company front windows with several, and a few tests on my own car, here is the final that looked the best.
* One-sided image
* Clear backing vs. white or gray
* 2-1/4" diameter
* Using water to apply like window tint, without air bubbles
Info:
* $2.00 each / Three for $6
* Maximum of three per member please
The dual-sided was too dark, the white backing showed too much grain against the blue sky. The one-sided clear looks really different. When outside in the sun, the daylight shines through the backside of the sticker and sort of alluminates it a bit. Sort of a neat suprise.
Anyhow, all of you that have actually been reading this thread will get first crack at the first batch. I ordered 50 this time, and when they run out I'll order more. So, if we can keep orders to a maximum of three per person for now, that would be helpful for others. Any large orders will need to be discussed.
I will post this later on it's own thread, but here is the address to send your self addressed stamp envelop, money order or to...
Money Order / check payable to:
Duane Cooney
Note: write your Club Cobra Member name on the check, just in case I need to contact you about anything later... Don't forget to send your self-addressed stamped envelop.
Address:
CC Decals
24988 Blue Ravine Rd.
#108 PMB126
Folsom, CA 95630
Duane
